10-08-2009 10:25 AM
Hi
I am trying to do a constrained Levenberg Marquardt fit. How can I set up the function by using the template ? I attach here the regular LM fit I have, with some (poor) data.
thanks for help ( I read the help file but it is not too clear to me...)
regards
10-12-2009 04:56 AM
Hello nitad54448,
Thanks for posting on National Instruments Forum.
You can find on the links above some information about the Levenberg-Marquardt functions in LabVIEW.
What is the Difference between the two Levenberg-Marquadt VIs in LabVIEW
10-12-2009 11:56 AM
bonjour
merci pour la réponse .. le problème est comment définir la fonction dans template.. je vais y arriver un jour 🙂 !
cordialement
N
10-20-2009 04:09 PM
See if this post and example helps you. It shows you how to set up the reference to the f(x,a) subVI and use it to call the LM function. No constraints but it should help you out.
http://forums.ni.com/ni/board/message?board.id=170&message.id=448715#M448715
