value signaling property node not generating an event
I have an example program that uses a Property Node > Value(Signaling) to generate an event.  The property looks like this:
When I create a VI to do the same thing the Property Node looks like this:
I right click the boolean control, create, property node, value(Signaling) to create the node.
My VI does not generate an event when a TRUE value is passed to the property node.  Is there some way to change the Data Type to boolean?  Is this the problem?
Message 1 of 21
(8,716 Views)
It's hard to address your problem. The pictures don't show.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 21
(8,691 Views)
It is really best to just attach your example VI.  That way we can did into your settings as well.
GCentral
Message 3 of 21
(8,671 Views)
Have you read the help for Value (Signaling)?  (Right-click on the property node you created.)
Bill
CLD
(Mid-Level minion.)
Message 4 of 21
(8,653 Views)
Accepted by shall12
If the datatype of the value property node does not look like boolean (i.e. purple instead of green), you need to change the mechanical action of the boolean because it is currently latch action. Change the mechanical action to switch action and you should be OK.
Also note that a value(sgnl) property will fire the value change event unconditionally, even if the old a new value are the same.
(If you would like to be able to fire events of latch action booleans as you describe here, consider voting for this idea. :D)
Message 5 of 21
(8,647 Views)
Thanks.  I did figure this out.  I wonder why this did not generate an error telling me the latch was incorrect for the signal.
Message 6 of 21
(8,630 Views)
          EUREKA!!!! Its posible, only need use a type cast to a normal boolean.
           Here the solution:
Best Regards,
Luis A. Mata C.
Ing. Electrónico
Whatsapp: +58-414-1985579
BBM Pin: 2B83E99A
Thanks: Kudos
Message 7 of 21
(8,238 Views)
Cute! 😄
You can create a constant on the upper wire and eliminate the dummy boolean. Still works. 😉
Message 8 of 21
(8,220 Views)
altenbanch: "You can create a constant on the upper wire and eliminate the dummy boolean. Still works. :smileywink:"
Yes, I know, just showing where get the datatype.
Luis A. Mata C.
Ing. Electrónico
BBM Pin: 2B83E99A
Thanks: Kudos
Message 9 of 21
(8,205 Views)
Luis mined the gemstone and Alt polished it up!   Excellent!!!  This will come in handy...
Bill
CLD
(Mid-Level minion.)
Message 10 of 21
(8,202 Views)
