viファイルを開くときのエラー
 すでに作成済みのviファイルを別のLabVIEWで開いたときに"NI-VISA Driver support for LAbVIEW 2020 is missing ..."と表示されてしまいます.
 また,同ファイルのブロックダイアグラム上にすでに置かれている計測器I/Oアシスタントをダブルクリックしたところ,"Instrument I/O Assistant is not installed"との表示が出ました.
 NI-VISAと計測器I/Oアシスタントはすでにインストール済みのはずなのですが,バージョン等の問題でしょうか.ファイルを開いた"別のLabVIEW"等のバージョンは以下のとおりです.
・LabVIEW Community Edition 2020 SP1
・NI-VISA 2022 Q3
・NI-488.2 2022 Q4
・OS: Windows10
(735 Views)
Hello! This forum has no translation support. Please write in English or paste text translated to English here.
(708 Views)
   I have already had a VI file and opened it in a different PC, which includes
-LabVIEW Community Edition 2020 SP1
-NI-VISA 2022 Q3
-NI-488.2 2022 Q4
-OS: Windows10
-the Instrument I/O Assistant
   While I have already installed the NI-VISA, the error said that "NI-VISA Driver support for LAbVIEW 2020 is missing ..." when I opened the file.
   And while I have already installed the Instrument I/O Assistant, the error said that "Instrument I/O Assistant is not installed" when I clicked the Instrument I/O Assistant in the block diagram.
Would you teach me what is wrong in this case?
(697 Views)
So, there is VISA from 2022 installed, but LabVIEW from 2020? That would be solved by either altering the VISA installation via the source installer, or use the NIPM to add VISA support for LabVIEW 2020.
(693 Views)
I installed the VISA 20.0, but the results are the same.
What should I do next ?
(673 Views)
