vi sever error 56
Hi all.
I am controlling a labview built application ( this site examples) using vi server.
Everything runs fine in development machine. When the executable is installed in a remote machine whith labview runtime only, I can not control it trhu the LAN. No firewalls.  error 56
tcp.enabled true and port are configured in ini file of exec.
I searched this site but found no solutions.
Should I install full labview in remote machine?. Is there any vi server runtime? Am I doing something wrong?.
Thanks a lot.
Alipio.
"Qod natura non dat, Salmantica non praestat"
(2,153 Views)
Accepted by alipio
This is timeout error. Check your firewall settings. May be it is not allowing the data to come in and your program is waiting for the data so causing timeout error.
U dont need to install labview to remote PC dont worry Smiley Very HappySmiley Very HappySmiley Very Happy.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,141 Views)
Thanks a lot.
I  will talk to the netwoek responsable to get a suitable configuration.
Alipio.
(2,129 Views)
