visa read write to serial port independently & simultaneously !
Hello all !
I need to read and write data to and from a serial port (rs232) independently and simultaneously .
i'm sorry that i can't put a picture of this but it is very simple :
i used "configure serial port" and passed the resource reference to two while loops.
one loop is reading data and the other loop is writing data to the port.
the problem is when the read loop (read from serial function) waits for data - it locks the other loop from running (write to serial function is blocked).
i searched the forum and find that visa open function has "duplicate session" option - is this what i need ?
if true, can anyone explain exactly how to wire and use it in the correct way ?
thanks a lot.
guy.
Message 1 of 9
(8,466 Views)
I have no idea how you did your coding so that one loop is blocking the other since you don't want to post an image. Going to be hard to tell you what to change.
Message 2 of 9
(8,456 Views)
hookso,
It is my understanding that a serial port may pass data bi-directionally, but the information cannot be passed simultaneously. You may need two ports or perhaps a parallel port.
Ben D.
Applications Engineer
Message 3 of 9
(8,435 Views)
A picture of my problem is attached !
Message 4 of 9
(8,412 Views)
Did you look at the shipping serial examples? Why don't you have a VISA Bytes at Serial Port and only do a read when something is there?
Message 5 of 9
(8,407 Views)
because i will have to poll the port all the time.i want my code efficient.
Message 6 of 9
(8,394 Views)
I fail to see how periodically polling for bytes is any less efficient than constantly doing a read that times out but the duplicate VISA session can be tried. It's an option with the VISA Open function.
Message 7 of 9
(8,377 Views)
Accepted by hookso
Ok , i found an example that solved my problem : a VI called  serialduplicatesessions.
The file is attached.
this is the link for any case : http://zone.ni.com/devzone/cda/epd/p/id/1727
Message 8 of 9
(8,351 Views)
It also solves my problem.  Thanks
Message 9 of 9
(6,066 Views)
