wavelet transfer function analysis
Has anyone implemented a transfer function analysis using wavelets?
By analogy awavelet power spectrum can be defined as the wavelet transformation of its autocorrelation function.
Similarly it should be possible to calculate a cross-wavelet transformof two time series and a cross-wavelet coherence.
Can this be doen using LabVIEW?
(3,469 Views)
Hi Prof Dee,  you can do it with the Advanced Signal Processing Toolkit
Check this intro to the wavelet processing:
https://zone.ni.com/reference/en-XX/help/371419D-01/lvasptconcepts/wa_intro/
(3,435 Views)
Thanks for your replies. I think I need to supply more details of the problem.
I am looking to find Gain, Phase and Coherence to test the relations between a stimulus and response as is done in the waveform measurements frequency response function.
(3,426 Views)
I found a forum where they use Labview with a Matlab script for the coherence analysis, check it out
http://forums.ni.com/t5/LabVIEW/Can-Labview-perform-wavelet-coherence/m-p/1881209#M635706
(3,387 Views)
Also chekc the helpme file for the WA Configure Scalogram Indicator VI
Displays the square magnitude or the phase of the wavelet coefficients on an intensity graph.
https://zone.ni.com/reference/en-XX/help/371419D-01/lvwavelettk/wa_plot_scalogram/
(3,381 Views)
Thanks for these suggestions.  I have reached the conclusion that LabVIEW is not capable of Wavelet Transfer Function Analaysis whereas MatLab is.  I don't have Matlab, so will have to wait until National Instruments expands the wavelet function in LabVIEW to match those in Matlab (if ever).
(3,313 Views)
