11-05-2009 12:49 AM
when I send date as dd/mm/yyyy to excel spreadsheet with Activex, date string changes to mm/dd/yyyy. I am from Australia date format on my computer is dd/mm/yyyy.
I have selected date cell format as dd/mm/yyyy. Any ideas. Thank you.
11-05-2009 01:40 AM
11-05-2009 06:05 AM
I found a similar problem. All my settings in Windows were for UK formatting, but on occasions [not always!] the date as shown in Excel was reversed, so I would send, for example 05/11/2009 and the "system" would mangle this to be in May. I found a way round was to send the date as 05/Nov/2009, and Excel would then display 05/11/2009. I did suspect that if the date was valid either way round, as in my example it would be reversed, but if the day was above 12 (as in 20/11/2009) it was OK, but having got a solution, I didn't investingate further.
If you're using "get date/time string" I think that the UK long date format of "05 November 2009" will also work.
I'm presuming the Australian date format is the same as the UK.
Rod.
11-05-2009 07:05 AM
Similar problem to Rod's one - with Italian date format which is dd/mm/yyyy - when writing dates to Access using the Database module.
When day is > 12, I must prepare the date as yyyy-mm-dd (format for Database module vi's); when day is <=12, the date must be prepared as yyyy-dd-mm.
This problem really astonished me. Must be something about ActiveX and Microsoft stuff.
satinder, does the behaviour change with day number too?
