who can help make a labview program to control temperature. Example: when the temperature drops below 20deg the air-con turn off
 who can help make a labview program to control temperature. Example: when the temperature drops below 20deg the air-con turn off (i need this for sch project) thx
(2,050 Views)
Since this is for a school project, you should do it yourself. 1. So that you learn something. 2. So that you do not take credit for work done by others.
We will help you understand how LV works. We will not do your project for you.
The best way to get help is to ask specific questions.
How will you be sensing the temperature?  How will you be controlling the air conditioner? How will the user interact with the program? How will you implement safety features such as over temperature or undertemperature conditions or the minimum off time for the air conditioning compressor?
What kind of data acquisition equipment do you have?  What version of LV are you using?
Lynn
(2,048 Views)
