write 1d cluster continuously in csv
It works here 😄
Tks.
 But now  I have other problem, when i try  to verify the data that i've saved, I see   same data -0,0001 a lot,  Does the conversion is wrong ? .
see the files
Message 11 of 18
(1,436 Views)
Hi josi,
it's the way you convert from float to string. Read the help of those functions!
Message 12 of 18
(1,433 Views)
josi_ocroch wrote:  But now  I have other problem, when i try  to verify the data that i've saved, I see   same data -0,0001 a lot,  Does the conversion is wrong ?
What does the data from the scope say?  I recommend doing a single acquisition and compare what is in the chart versus the data file.
Also, you need to add a line to the end of your header to move the first data point to the next line.
GCentral
Message 13 of 18
(1,429 Views)
The scope reads some amplitude and time data from two differents signals.
Actually,i have some difficulties to split this data and put them in the excel because i do not know  exactly which data represents each chart.
Message 14 of 18
(1,414 Views)
see the files
Message 15 of 18
(1,412 Views)
Accepted by josi_ocroch
Well, it would help if you understood what the data you were look at was.  Use the Context Help and look at what the cluster is that you are reading.  You will see that the array inside of the cluster is the actual waveform.  So this is likely closer to what you are looking for (may need a Transpose 2D Array in there).
GCentral
Message 16 of 18
(1,390 Views)
it works 😄
Tks Cross ruiz 😄
Message 17 of 18
(1,361 Views)
Don't forget the dt. Without it, the data is likely to be useless down the line.
Message 18 of 18
(1,353 Views)
