write to measurement file - Create or replace with confirmation
I'm using the "Write to measurement file.vi" and I want it to ask for confirmation if I try to save with a filename that already exists and then allow me to choose another file name or overwrite the old one. How can I do this?
Message 1 of 28
(3,821 Views)
In this Express VI, select the box "Ask user to choose file."
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 2 of 28
(3,817 Views)
I've done this. The only options it has are:
  • Rename existing file—Renames the existing file if Reset is TRUE.
  • Use next available name—Appends the next sequential number to the filename if Reset is TRUE. For example, if test.lvm exists, LabVIEW saves the file as test1.lvm.
  • Append to file—Appends the data to the existing file. The VI ignores the value of Reset if you select the Append to file option.
  • Overwrite file—Replaces data in an existing file if Reset is TRUE.
But I want to have it ask for confirmation to overwrite, then let you save it as a different name if you want. Is there any way to combine something with this vi to do this, or do I need to find another vi that would let me do this?
Message 3 of 28
(3,807 Views)
Accepted by SuSto
That Express VI does not have the capability you are seeking. You will need to either convert it to a regular VI and modify it, or simply add some code to do what you seek. THis can be accomplished quite easily with the File I/O functions.
Message 4 of 28
(3,804 Views)
@smercurio_fc wrote:
That Express VI does not have the capability you are seeking. ...
Help us Obe Wan, you're our only hope.
Ben
Message 5 of 28
(3,800 Views)
Ben
Did I misunderstand the question again?
Message 6 of 28
(3,797 Views)
Ben
No.
Spoiler
Your wording reminded me of the scene from Star Wars when Ben Kanobe di dthe force thing on the strorm troopers telling them "These are not the droid you seek."
Its just Friday.
Ben
Message 7 of 28
(3,793 Views)
Ben wrote:
No.
Spoiler
 Its just Friday.
Ah. Gotcha, Kimosabe.
Message 8 of 28
(3,781 Views)
Is there a way to combine the "write to measurement file express vi" with the "open/create/replace file" function? Or, more basically, is there a way to wire any file path through another function and into the "write to measurement" vi?
Message 9 of 28
(3,749 Views)
Of course, but you don't want to modify any LV functions (I don't know that you can).  This question seems so basic (too basic) perhaps I misunderstand what you are saying, but you can wire any reference through one of your VIs.
Message 10 of 28
(3,747 Views)
