write to measurement file - Create or replace with confirmation
You need to provide a sample file so I can understand exactly what you mean.
Message 21 of 28
(1,066 Views)
yeah... please find the attached file
Message 22 of 28
(1,062 Views)
So you are reading two other files and trying to append one to the other and write to a new file? Can you post your code that does that?
Message 23 of 28
(1,054 Views)
please see my code and while reading that datas showing some errors but if i stopped and start the vi once again we can read the append datas
Message 24 of 28
(1,052 Views)
I looked at your code and in order to append data as you want to a measurement file, you must add the new data as new channels. Measurement files are based on channels. Writing the same number of signals over and over will simply append the data to the end of the existing data. I already mentioned that you can merge your NEW data signals with the OLD data signals to get the desired effect.
Example, your 2D array has 4 rows...that creates 4 channels of data in the measurement file. If you take your 2D array of 4 rows and append data to make it 8 rows and then write to the measurement file, you will have 8 channels in the measurement file. If you already wrote 4 rows and then write 4 rows again, the new data will be appended to the existing 4 rows. This is one of the drawbacks of the Express VI. Otherwise, I would suggest using the TDMS file primitives.
Message 25 of 28
(1,018 Views)
Hi actually i am new to this LabVIEW can you show any example VI
Thanks in advance
Thank you for your time consideration and forthcoming response
Message 26 of 28
(1,016 Views)
Hi i tried and changed simply changing the convert from dynamic data 2D row as a channel to 2D array of column as channel
Message 27 of 28
(1,003 Views)
Your data looked to be correct for "row as channel", but if you transposed it and it works for you, great.
Message 28 of 28
(998 Views)
