LabWindows/CVI Idea Exchange
vix
ATTR_DIMMED for SetTreeItemAtribute()
A tree control can be used to implement radio button controls;
in this situation you can't completely dim one of the items (so that it is grayed and the user immediately sees it is inactive) because the function SetTreeItemAttribute() doesn't allow ATTR_DIMMED attribute.
You can dim the item label using SetTreeCellAttribute(), but the check box stays active (see this discussion).
The EVENT_MARK_STATE_CHANGE can be swallowed, but the check box has the aspect of an active check box, even if nothing happens when you click over it.
I suggest to add the attribute ATTR_DIMMED to SetTreeItemAttribute() so that the whole item can be dimmed (its check box too)
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
3 Comments
LuisG
NI Employee (retired)
Status changed to: Under Consideration
LuisG
Status changed to: Completed
LuisG
