LabWindows/CVI Idea Exchange
vix
Add a EVENT_VAL_COERCED
Status: Completed
If you have a Numeric Indicator, and you set "Range checking" to Notify, CVI will show an ugly popup when you enter a value out of range.
If you set this property to "Coerce", the value you enter is coerced in range, but no specific event is generated.
I think that an EVENT_VAL_COERCED would be really useful: using this event you could easily show a message popup, for example.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
5 Comments
LuisG
NI Employee (retired)
Status changed to: In Development
Laura F.
Status changed to: New
prior status deleted, setting to default
LuisG
Status changed to: Under Consideration
LuisG
Status changed to: In Beta
LuisG
Status changed to: Completed
