I'm using the 3D Graph ActiveX in order to display contour lines for a given parameter.
I would like to overlay this contour map with a Google earth image as shwon below.
So it would be nice to consider adding the possibility to add a bitmap image to the 3D graph as it is possible to add a bitmap as background of a canvas control. The bitmap could also be used to replace the color of a surface plot.
