LabWindows/CVI Idea Exchange
Laser
Avoiding recursive warnings while debugging
Status: New
in many of my applications, I have to verifiy some conditions recursively and they can generate an error, for example when checking the presence of a file (see below).
Imagine to have a task doing this, and imagine the task is scheduled every 5 seconds or less.
This means you'll get the popup window continuosly and it makes almost impossible to debug your code.
I know I can reduce the Debugging level from Extended or Standard to No RunTime Checking in order to block that popup window, but sometime I need a deeper level of debug to fix my problems.
What do you think about adding a third button to ignore, for the current debugging session only, the run time errors generated from the same instruction?
More, what do you think about adding a fourth button to ignore, for the current debugging session only, the run time errors of the same type?
Regards
Sergio
2 Comments
RavensFan
Knight of NI
How did you embed your image in the message?  However you tried to do it was wrong, it didn't work.  It just shows the red X box.
Try again.
RobertoBozzolo
Proven Zealot
This thread should be considered closed as Laser as republished it with the correct image here.
