LabWindows/CVI Idea Exchange
Laser
Avoiding recursive warnings while debugging
Status: New
in many of my applications, I have to verifiy some conditions recursively and they can generate an error, for example when checking the presence of a file (see below).
Imagine to have a task doing this control and imagine the task is scheduled every 5 seconds or less.
This means you'll get the popup window continuosly and it makes almost impossible to debug your code.
I know I can reduce the Debugging level from Extended or Standard to No RunTime Checking in order to block that popup window, but sometime I need a deeper level of debug to fix my problems.
What do you think about adding a third button to ignore, for the current debugging session only, the run time errors generated from the same instruction in the same thread?
More, what do you think about adding a fourth button to ignore, for the current debugging session only, the run time errors of the same type?
Regards
Sergio
2 Comments
CVI-User
For your case, you can use bole=SetBreakOnLibraryError(0), then SetBreakOnLibraryError(bole) to guard the FileExist() or other CVI functions you know they might fail. But sometimes a "Ignore this non-fatal error caused here"-Button might come handy.
/* Nothing past this point should fail if the code is working as intended */
Wolfgang
Trusted Enthusiast
We seem to have similar requests, see here. I don't mind if it's a right-click menu or an additional button allowing to temporarily exclude certain errors - so let's advertise it Smiley Wink
