I don't know if it is possible technically but from a user's perspective it would be convenient for debugging a program (in debug configuration) if the UI constants could be provided in the data tooltips, too. Right now, if something is wrong with my UI I will have to do a lot of detective work to find out which control / control attribute is the problematic one...
Example: Consider the code
SetCtrlAttribute ( panel_handle, control_id, control_attribute, attribute_value );
Right now, if I hover over attribute_value, the tooltip will display something like "attribute_value = 24064". Then I will need to look up userint.h to find out which attribute value this is ( ATTR_CTRL_VAL ). It would be more convenient if the tooltip could include this information, too, and display something like "attribute_value = 24064 ( ATTR_CTRL_VAL )"
The same holds for control_id, because a number such as 14 will not immediately help me - I will have to go through the corresponding include file to find the respective UI control (e.g. TABPANEL_2_NUMERIC ).
