LabWindows/CVI Idea Exchange
40tude2
Documentation tags improvement - New tags that define blocks
Status: New
So far the documentation is written line by line with a tag at the begining of each line. See below :
/// HIFN Document your function here.
/// HIFN You may use multiple lines for documentation.
It could be nice to add a tag attribute that helps to define regions (or blocks) of documentation. See below :
/// HIFN BEGIN
//  Document your function here.
/// HIFN END
Once done this would help to copy/paste large section of existing documentation. Regarding the "// " that need to be added I believe that a macro or a new editing option ("comment multiline" or "comment selection" like in VBA) could do the job 🙂
Regards, 40tude
1 Comment
40tude2
Ooops!
Regarding the very last part of the previous post about commenting I realize the option is "almost" already there
Indeed when some lines are excluded the "Comment" button of the Edit/Resolve All excluded lines option already add "// " at the beginning of the lines.
This is a pretty good news because this means less work to implement the proposed idea 🙂
Regards, 40tude
