One of the more valuable tools within LabWindows is the ability of the editor to fill in struct elements given the struct name. I also work with Eclipse-based tools for embedded systems work, and it has a similar ability. Unfortunately, whereas Eclipse dynamically analyzes the code as it is written, and can provide stuct elements (and other variable information) as soon as the programmer types it in, LabWindows cannot provide this information until after the code has been successfully compiled. As this may or may not happen for some time after the file has been started, or major changes begun, it is almost useless.
Another useful tool that Eclipse offers that LabWindows does not is the ability to refactor variables and other symbols. Again, Eclipse dynamically tracks the code as it is written, not requiring compilation; refactoring is similar to global replace, except that it tracks the 'C' usage of the symbol and only changes the proper usage. So, for instance, if I use a local variable named "X1" in three different subroutines, and refactor "X1" to "X2" in one of them, only the variable in the particular routine gets changed.It works with any C symbol, including routine names, global and static variables, and structures.
As a matter of fact, I would encourage NI to look into the possiblity of basing LabWindows on the Eclipse platform, as Atmel did in replacing its proprietary Studio software with an Eclipsed-based version. This would enable users to take advantage of a large number of available Eclipse tools, such as source-code management.
