LabWindows/CVI Idea Exchange
andreas.he
Generate Function Tree..."
Status: New
To export enum types with a dll there is a fine menu "Generate Function Tree...". Using the Help Buttom, one finds is a description on how to use it. It is mentiond not to nest the different comment type. "Avoid nested comments or combinations of comment styles ...... (backslashes, stars, etc.), what I understand. - Unluckily, if one uses comma "," or semicolon ";" within a comment, the tool fails with "I n v a l i d enum typedef.", what I consider is a bug. This makes the tool less valuable, especially if one resuses C source code from thirdparties.
