sometimes i use the table object in CVI but there is one function that is missing and i think it's really usefull, the one that give you the ring index directly.
now i'm doing it in this way, maybe there is a better way to do it but i've not spent too much time to do it.
/// HIFN This function give you the item ring index. /// HIRET an integer value containing the function result. /// HIPAR panel/panel handle where the control is located. /// HIPAR control/which control i have to analyze. /// HIPAR column/in what column i have to look. /// HIPAR row/in what row i have to look. static int GetTableIndex(int panel, int control, int column, int row) { int Result = {0}; long IndexLength = {0}; char *IndexTemp = {0}; GetTableCellValLength(panel, control, MakePoint (column, row), &IndexLength); IndexTemp = calloc(IndexLength + 1, sizeof(char)); GetTableCellAttribute (panel, control, MakePoint (column, row), ATTR_CTRL_VAL, IndexTemp); GetTableCellRingIndexFromValue (panel, control, 0, MakePoint (column, row), &Result, IndexTemp); free(IndexTemp); IndexTemp = 0; return Result; }
