LabWindows/CVI Idea Exchange
Johannes_T
Improve Breakpoints Window
Summary:
Improve the Breakpoints Window, so that breakpoints can be more easily managed.
Description:
1. Change the Breakpoints Window, from a modal dialog to a dockable window (similar to the Watch Window). Debugging can be more easy this way.
2. Allow breakpoints to be grouped, disabled/enabled and edited in user defined categories. This allows users to easily collectively manage several breakpoints at a time. It also helps the user to logically group breakpoints, depending on various issues issues that he might be working on.
3. Breakpoints could also be sorted from a pop-up menu by filename, line, hit count, etc.
Breakpoints Window
1 Comment
LuisG
NI Employee (retired)
Status changed to: Under Consideration
