When operating graphs in Labview, it is easy to change the scale of an axis of a graph (at runtime): to change e.g. the maximum value, you select the current maximum value with your mouse, type in the maximum number you want and hit enter. To achieve the same in Labwindows, you have to use a numeric control and a button, which is a bit cumbersome. The same applies for zooming: In Labview, you can click a small button attached to the graph and select the way you want to zoom, and then just use the mouse. In Labwindows, you have to know that zooming is done using the ctrl button, ctrl+space restores the previous setting, etc. It would also be nice to be able to enable autoscale by right-clicking on an axis and having a popup menu which allows to do so (just like in Labview). And if the user changes e.g. the maximum value while autoscale is enabled, it would be nice to automatically disable autoscale (unlike in Labview).
So in general, it would be nice to have more comfort in operating graph controls.
Thanks.
