We have recently dropped CVI (as of 2009) as an option for use with our many data visualization applications. The graphic performance is just too slow and clunky to put up with any longer and gets worse as we add features or try to make 'native looking' applications (that resize, animate, etc).
Things like dragging/updating cursors is noticably clunky when you have more than one graph updating (linked cursors across more than one graph).
Updating datasets in large tables is slow enough to watch it step through the rows. Even using suggest tips like using ATTR_CTRL_VAL instead of SetTableCellVal, when a large table has to update... it's painfully noticeable. Basically any operation that updates a large portion of the UI.
Another example, try to resize and move controls (as most other applications do) on the EVENT_PANEL_SIZING?
I'm going to go out on a limb and guess that CVI doesn't use any graphics card acceleration? since workstation or netbook doesn't seem to make much difference in graphic performance.
Our clients notice when our applications look 'clunky' and 'slow' when compared to smooth, responsive apps/interfaces from competitors. It's often the little things that make a big difference in appearance.
Greg
We are removing the "Under Review" status from the Idea Exchange. Therefore, we are moving this idea to the "Under Consideration" status.
