LabWindows/CVI Idea Exchange
RobertoBozzolo
Panel callbacks
Status: Completed
At present, the only option to jump to a panel callback is Ctrl-P shortcat from the UIR editor (or Code >> View >> Panel callback menu selection). Even longer is to generate a panel callback, which can only be done via Code >> Generate >> Panel callback menu chain.
I'd like to have added two options to panel context menu in the UIR editor: Generate Panel Callback and View Panel Callback, in the same way as those options are present in a control context menu; something like this:
12 Comments
ngay528
I definately agree with this one.  This took me a long time to figure out when I first started with CVI and didn't know I had to navigate the menu.  Instead, I just copied the default panelCB one that is autogenerated and changed then name.  Both a Generate panel callback and View panel callback should be implemented.
In addition, there also needs to be one for Menu Callbacks to generate and View
RobertoBozzolo
Proven Zealot
Hi ngay, there actually exists a context menu for menu callbacks: if you design a menu and attach it to a panel, in the UIR editor you can click on the menu and show it, next you can right-click on a menu item and have the usual Generate / View items (see this post from Luis)
This feature does not work for top level menus without child items (items that appear with the exclamation sign).
LuisG
NI Employee (retired)
Status changed to: In Development
ngay528
Aha!  is that new?  I swear I must be crazy.  Thanks for pointing that out Rob
Laura F.
Status changed to: New
prior status deleted, setting to default
LuisG
Status changed to: Under Consideration
LuisG
Status changed to: In Beta
PerBorgvad
Maybe it's allready there, but I would like to have a control like these popup menues. Obviously free programable from the GUI
editor and from code.
RobertoBozzolo
Proven Zealot
Not sure if this is what you're looking for, but you can design your own menu in the UIR editor, load it with LoadMenuBar without assigning it to any panel (passing 0 to destination panel handle parameter) and show it with RunPopupMenu, See this example
LuisG
Status changed to: Completed
