When using tab controls on a panel, every time you change the active tab in the UIR editor the file is marked as modified even if no real modification has been made on panels/controls. This is particularly annoying when you are simply looking at a UIR file but you don't want its date/time to be modified (e.g. in case the project has already been deployed to the customer and you want to keep the local copy of the UIR with the original date/time).
If your file is marked as read-only (same scenario as before: the application has already been deployed and you want to prevent modifications to it) you cannot even change the active tab page, neither in edit mode nor in operate mode (F4 - operate visible panel)!
It would be better in my opinion that a simple tab page switch does not forces the UIR to be saved.
