When you click on a control on a panel in the *.uir file while in the Operator mode using the Integrated View, you can view the user interface events that are generated in the lower left corner, as seen below in the red box.
However, if you prefer to use the classic view, these events are not visible in the floating window that contains the *.uir file when you click on a control in the Operator mode.
Knowing these events can be useful when choosing which events to create callbacks for, and clicking on controls is a very easy way to play around with it.
