LabWindows/CVI Idea Exchange
gdargaud
Set breakpoint on control attribute change
Somewhat similar to SetBreakOnLibraryError, I suggest the addition of a function that does a breakpoint when the specific attribute of a panel/control changes.
It could work like this:
SetBreakOnCtrlAttributeChange(panel, control, Attribute)
with also:
ClearBreakOnCtrlAttributeChange(panel, control, Attribute) // Use -1 to clear them all
SetBreakOnPanelAttributeChange(panel, Attribute),
ClearBreakOnPanelAttributeChange(panel, Attribute) // Use -1 to clear them all
Example of use:
SetBreakOnCtrlAttributeChange(panel, control, ATTR_CTRL_VAL)
SetBreakOnCtrlAttributeChange(panel, control, ATTR_VISIBLE)
3 Comments
LuisG
NI Employee (retired)
Status changed to: Under Consideration
LucianoAssirelli
Definitely useful, when an attribute changes and you cant find where/when you did it
ElectroLund
This is a great idea.  Sadly, I searched the forums for this kind of feature and found that it doesn't exist.
It might also be helpful to be able to set a specific value to break on for a control (like for the ring controls).  Something like this:
SetBreakOnCtrlValChange(panel, control, 7)
