LabWindows/CVI Idea Exchange
40tude2
Source code editor : highlight search results + implement ALT+Up/Down arrow (move lines) and others ideas
Status: New
CTRL+Q should highlight all instances of the results in the editor
Same thing with CTRL+F
This is similar to Notepad++ for example
I find the ALT+UP ARROW and ALT+DOWN ARROW of Visual Studio 2013 quite useful (move selected lines)
Please, implement CTRL + L to delete a line
I know the short cut is already owned by "go to line" but my current macro is not that good 😞
It seems macros are not working in the editor while debugging a code.
Could be usefull.
Will be mandatory if one day the "Comment multiple lines" is implemeted using a macro 🙂
Best regards, Philippe
3 Comments
RobertoBozzolo
Proven Zealot
With reference to your suggestion for Ctrl+L, please note that shortcut keys can be reassigned with Options >> Change shotcut keys menu function. In particular, in Miscellaneous section you can find Cut Line to Clipboard option that you can change as you want. I don't remember which is the default assignment: I have changed it to Ctrl+Y for historical reasons when it changed in one version upgrade (I seem to remember it was in CVI8.5).
40tude2
Thanks a lot for the CTRL+L and/or CTRL+Y (have you been using Wordstar under DOS as well ? Smiley LOL). I deleted my macro and find "my" CTRL+L.
By the way do you know if one created a shortkey file (kbs) which would make CVI acting as Visual Studio? I'm pretty sure the CVI team must have this issue while navigating between both environments.
I'm always lost between the CTRL+F7, F5, SHIFT+F5 etc...
uriyal
Highlighting searched text is a great idea. you have to implement this.
