As discussed here earlier I am using tooltips that show 'dynamic' information, e.g. the permitted data range of the respective control, available user actions..., These frequently depend on several other controls and parameters.
Right now, all other affected controls etc. need to call a function to re-build the tooltip text, and to more than 90% this is wasted effort because the tooltip text is changed again before it may get displayed...
Thus I would like to suggest a 'dimmer callback', similar to the menu dimmer callback. This 'tooltip dimmer callback' should be called just before the tooltip is going to be displayed, allowing to build/update the tooltip text only when needed.
