LabWindows/CVI Idea Exchange
Wolfgang
UI editor: Find controls in C code and Allow copy & paste from status bar
searching through the C code for specific controls first and foremost requires the knowledge of the control's name... If there are some hundred it may get difficult to remember and thus I typically have to check the UI for the constant name. Clicking on the control shows its name in the status bar, a welcome feature, but unfortunately I cannot directly use this text for searching...
What I suggest is allow copying this status bar field using CTRL+C; then it's possible to switch to the C code, press CTRL+F and CTRL+V... (The property browser is not really useful here because it only lists 'NUMERIC_7' and misses the associated panel)
Another, even more powerful feature would be to add a right click popup menu either to this status bar field ('Search C code for this constant') or to the control popup itself: Besides 'Generate control callback' etc. I'd like to see another entry 'Find control in C code'
Thanks!
1 Comment
LuisG
NI Employee (retired)
Status changed to: Under Consideration
