I'll continue my quest for better statistics support in CVI... While LabView provides a VI to calculate percentiles of an array, there is no built-in function in CVI
In case you are wondering what the purpose of percentiles is: it is as important as the standard deviation for robust statistics, i.e. instead of calculating the mean and the standard deviation one would choose to calculate the median (possible with CVI) and the 25 and 75 percentiles; the difference (sometimes called the interquartile distance, IQD) is a measure for the width of the distribution.
Robust statistics is valuable of one has to deal with outliers.
Hence I ask for a function to calculate percentiles; may be, if NI is generous, they may even supply a function to calculate IQD
