I have a minor but well-hung suggestion: In case that one is changing the workspace to a different project while the Resource Tracking window is open, this Resource Tracking Window should be closed.
As discussed in some detail here the Resource Tracking Window should only show up if there is a memory leak - so after a new project is loaded CVI can't know if there is a memory leak, and hence it should not cause confusion by staying open 😉
