04-08-2015 11:56 AM
After I go to BUILD >> CONFIGURATION >> MANAGE CONFIGURATION >> RELEASE >> EDIT >> TARGET SETTINGS, then either type in a new name in the APPLICATION FILE field, or actually browse and select the file that I wanted it to be named to, and select OK >> DONE >> DONE. It does not get change.
Ver 2010
04-08-2015 12:12 PM
I cannot comment on CVI 2010 but CVI 2013SP2 behaves as expected.
What do you mean by 'it does not get changed'? No file name is expected to be changed; if you enter a new file name for the release executable the next time you generate a release executable this new file is supposed to show your new name.
Let's assume your current configuration specifies 'NAME_1.exe', building a release executable will give you NAME_1.exe. Now, if you change your release configuration to 'NAME_2.exe', the next time you build a release executable the file will be called NAME_2.exe, but the old executable NAME_1.exe will still exist.
04-08-2015 12:22 PM
Yes I am doing exactly that, but when I build the executable it is still shows NAME_1.exe. Also if I just go right back in to see if the changes have taken effect before I build, it still shows it as NAME_1.exe and not NAME_2.exe that I had priviously changed to.
04-09-2015 01:40 AM
Have you tried to give it directly in Build >> Target settings panel, selecting Release configuration and typing in the name? I always do this way and the name actually changes.
04-09-2015 08:42 AM
04-09-2015 10:25 AM
Thanks RobertoBozzolo, that worked. And when I do the direct BUILD >> TARGET SETTINGS and change the name, then go dirictly to BUILD >> CONFIGURATION >> MANAGE CONFIGURATION >> RELEASE >> EDIT >> TARGET SETTINGS, I do see my changes there.
Looks like this is a bug.
