09-03-2014 07:44 AM
Hello Wolfgang,
Now I see what you are talking about. You are making changes in uir that normally shouldn't change the header file.
In 2013 SP2 there is indeed a change to the uir header file.
On the 3rd line before SP2 there used to be a comment like:
/* Copyright (c) National Instruments 2014. All Rights Reserved. */
This was removed in SP2.
So when you first save the *.uir in SP2 the UIR generated header file is re-written with this change.
Constantin.
09-03-2014 08:04 AM
ah, good, thanks! So the answer to my question is yes, 2013SP2 files are different
09-03-2014 08:08 AM
Yes, the UI header files are changed.
