LabWindows/CVI
Auto detect serial port settings using LabWindows
Smiley Sad
Thank you for your help anyway
Message 11 of 18
(3,340 Views)
Accepted by paly_Andrew
Hi Andrew,
I suggest you to look at this thread and test Martin library to find available COM ports: it seems to me that it should be of much help in your trouble.
Message 12 of 18
(3,335 Views)
Thank you so much! It works! It's the second time you help me out. You are awesome!!!
Message 13 of 18
(3,323 Views)
You're welcome!
That's what the forums are for: something with a little more experience or (like in this case Smiley Wink ) a better memory can help other users to use CVI better and better. I learned a lot through forum posts and continue learning.
Message 14 of 18
(3,308 Views)
* Deleted *
Martin
Certified CVI Developer
Message 15 of 18
(3,285 Views)
@Roberto Bozzolo wrote:
Hi Andrew,
Since that thread I posted source code that works in CVI, without the need for the DLL. See this post.
Martin
Message 16 of 18
(3,282 Views)
Thank you Martin for pointing us to that thread: I updated my tags Smiley Happy
Message 17 of 18
(3,277 Views)
Hi Martin,
Thank you for sharing your solutions. When I tried to use this solution, http://forums.ni.com/t5/LabWindows-CVI/What-CVI-functions-do-I-need-to-use-in-order-to-check-the/m-p..., it gave me an error saying setupapi.h is not found.
I also tried your older one, http://forums.ni.com/t5/LabWindows-CVI/Check-com-port/m-p/221306#M16380. It worked, but the problem is that I need to combine it with other codes which use __stdcall calling convention when building it(since it need to link to some dll explicitly), while your solution need to use __cdecl.
Actually, I just wanna set up the port numbers automatically before starting the test program. Is it possible to combine them in either way?
Thank you so much.  I am looking forward to your response.
Tianchi
Message 18 of 18
(3,241 Views)
