1) It worked fine for me. I got the callback event to work using the objHandle for the CWNumedit from GetObjHandleFromActiveXCtrl(). Maybe if you post your code, we could see the problem.
2) If you look at the Online help for the ActiveX controls it will tell you under the help for CWAxis.FormatString. Here is the quote from the help that tells you how to calculate the value.
"With ActiveX controls, the date is implemented as a floating-point value, measuring days from midnight, 30 December 1899. So, midnight, 31 December 1899, is represented by 1.0. Similarly, 6 AM, 1 January 1900, is represented by 2.25, and midnight, 29 December 1899, is -1.0. However, 6 AM, 29 December 1899, is -1.25. To interpret the time portion, take the absolute value of the
fractional part of the number. Thus, 1 second equals 1 / 24 hours / 60 minutes / 60 seconds, which is 1/86400 or approximately 1.157407e-5."
Best Regards,
Chris Matthews
