LabWindows/CVI
CVI Project convertion error
When I do the convertion of CVI2010 Project in VS2008 IDE, a dialog which says "Cannot find the VXIpnp Directory." pops,how to deal with this problems? Thanks!
(4,135 Views)
Hello Simon!
Did you install the IVI Compliance Package?
(4,078 Views)
Hello Johannes_T! Thank you for reminding me,when I was installing the CVI2010,drivers were not installed.But where can I download  the  IVI Compliance Package which is matching with the installed CVI version(CVI 2010)?
(4,000 Views)
You can install the ICP from the following location: http://www.ni.com/download/ivi-compliance-package-4.4/2589/en/
Note, that if you also want to use the IVI Configuration utility, MAX also needs to be installed, which you can download from: http://www.ni.com/download/ni-device-drivers-2013.02/3802/en/
(3,991 Views)
