LabWindows/CVI
CVI graph axis update only when panel is active, but waveform update is done in inactive panel
i have got a problem when i want to save a panel screenshot with the functions GetPanelDisplayBitmap & SaveBitmapToPNGFile. The panel screenshot is done when panel is hidden or inactive. So some drawing events won't be done.
Please have a look into the attached screenshots:
1) manual measurement and saving operation, saved data is ok
2) hidden measurement and saving operation, saved data is not ok, the axis had not beend updated
3) bring the panel in front, axis had been updated
Is it possible to force a axis update without bringing the panel in front or set it as active panel?
Vitali
1)
2)
3)
Message 1 of 16
(4,911 Views)
Hi Vitali,
by "axis update" do you mean a graph refresh? (in your figures 1 and 2 the axes are identical)
Are you calling RefreshGraph / what is the value of ATTR_REFRESH_GRAPH?
I am not sure if I understood you correctly but you can update the graph on your panel without bringing the panel to front. For a smooth update, I hide the graph control, make all required changes, and display it again...
Message 2 of 16
(4,891 Views)
Hello Wolfgang,
thank you for your reply.
You see my problem: ..."in your figures 1 and 2 the axes are identical"..
In figure 2 the axes had not been updated. It is the axes information from figure 1 with the new data. In figure 3 you see the right axes for figure 2 after bringing the panel to front.
The function RefreshGraph does not update the axes when the panel is in background. This is my problem. I am woundering, why only the data is refreshed.
Message 3 of 16
(4,888 Views)
The software works in an automatic mode. So i don't want to show the panels in this mode. All actions will be done in background. The panel will be displayed only when the tester wants to observe what is happening in this module. The main application includes several modules with several panels.
Message 4 of 16
(4,887 Views)
Maybe i found my problem:
- my module uses following function before plotting the measured data points in the graph control and saving the panel screenshot:
   - SetCtrlAttribute (panel, PANEL_GRAPH, ATTR_VISIBLE, 0);
   - PlotWaveform
   - SetCtrlAttribute (panel, PANEL_GRAPH, ATTR_VISIBLE, 1);
   - Get panel bitmap and save bitmap to png
I can reproduce the behaviour with following example:
Message 5 of 16
(4,860 Views)
To reproduce the behaviour do following steps:
1) change number of samples per channel
2) click on Acquire
3) minimize the panel
4) wait until the screenshot is saved (change the path and filename in line number 169 in function SaveBitmapToPNGFile before)
5) compare the panel and the screenshot
Message 6 of 16
(4,860 Views)
Have you tried adding a ProcessDrawEvents or ProcessSystemEvents call just before the GetPanelDisplayBitmap call?
Message 7 of 16
(4,829 Views)
Yes, this does not help.
I found a solution. Before printing of any data points in the graph, you have to change the z-plane order and bring the control on the panel to the front. The panel can be hidden. Then the axes will be updated.
Message 8 of 16
(4,826 Views)
Accepted by vitali_R
I think this is a bug of cvi.
This is how it works:
- SetCtrlAttribute (panel, control, ATTR_ZPLANE_POSITION, 0);  //without this step the axes won't be updated!!!!!!!
- for each channel { PlotWaveform(..); }
Message 9 of 16
(4,825 Views)
If you don't do the z-plane trick and you put a breakpoint just before calling GetPanelDisplayBitmap, I assume the axes haven't beeen updated yet. But, if while your program is suspended at the breakpoint, you select Run>>Refresh User Interface, do they not update at that point? And if so, will the contents returned by GetPanelDisplayBitmap have those updates?
Message 10 of 16
(4,808 Views)
