LabWindows/CVI
CVI test executive txguiutl.c fatal error
I am trying to transfer a test application using the CVI Test Executive Tool Kit from a Windows XP machine to a Windows 10 64-bit device. The application starts but returns an error while running: "Fatal run-time error: txguiutl.c - line 899, column 73: Dynamic memory is corrupt." What could be the source of the problem and how to solve it?
(861 Views)
After select "Ignore" option there is following error: "file txguiutl.c, line 900, column 39 Null pointer argument to library function.".
(829 Views)
