05-18-2007 08:39 PM
05-22-2007 01:06 AM
05-22-2007 02:03 AM
03-03-2011 02:55 AM
Dear Allan
Did you manage to solve the problem. I am using Agilent frequency counter (53132A) and I want to store measurments in a output buffer of the frequency counter but I dont know how to do that.
I sent a question on this forum but did not get much response so I thought to ask you. Please help me
Thank you
Faheem
03-04-2011 10:08 AM
Faheem,
Can you store measurements how you want when you are just using the device, and not necessarily using LabVIEW at all? If so, how? That will be the first step to find out if you can do it while controlling the device with a driver. If you are not sure if you actually are given control over that, then you might get more ideas from the manufacturer. If you find out that it is something that you can programmatically control and what commands do it, then that should give direction for how to do it in LabVIEW.
Hope this helps,
Jen W
ni.com/support
