LabWindows/CVI
Cannot compile if windows.h is included
 Including window.h makes this project not compile in CVI 2015 Service Pack 1 [ Version 15.0.1 ( 239 ) ]
I am on Windows 7 64 bit
The project is just the example project except for the include at the top.
Cheers
Ram
(3,843 Views)
Your project compiles fine on my system: what errors are you receiving? Please post the build log so that we can examine it.
I see you have included several libraries and your project is a 64-bit one: are you sure you have the 64-bit release of each of them?
(3,809 Views)
Hi Roberto,
 Thanks for looking at this issue.  I have attached the build log.  Except for adding regex.fp, I have not added any other library to the project.  The compile errors are repeatable without adding any libraries.
Cheers
Ram
(3,786 Views)
The majority if not all errors refer to sal.h include file so the primary question is whether you have this file in your system or not.
I saw discussions in some other forums that claim that sal.h is not distributed with the SDK but is part of VS: I don't know who installed this file on my system but I know for sure I have some VS redistributables loaded by some installer.
(3,773 Views)
Accepted by performance
Rethinking to your situation,  it is difficult to imagine  that such a condition has not been addressed by NI or Microsoft when designing the IDE and the SDK; I would firstly check that all is correctly installed and configured.  What I would do is to:
1. Try running any of the shipping example that make use of the SDK and see if the very same errors appear
2. Try a repair install of both CVI and the SDK
3. Try a complete uninstall on NI software and the SDK and a fresh reinstall of them only
(3,764 Views)
Hi Roberto,
  Thank you for the idea.  starting with a shipping example [ winshape ] helped.  If I kept adding my old files in to this project, I was able to mess the project up again, but now I have a better starting point to investigate that.
Cheers
Ram
(3,701 Views)
