LabWindows/CVI
Could not open file for reading( Error code -5001)
Hello, I have problem with using Ini_ReadFromFile function.
If I build project in Debug64 version everything works fine.
But in Release64 version function return -5001 result (Could not open file for reading).
Here is code that cause problem:
	int section;
	char path[MAX_PATHNAME_LEN];
	sprintf(path, "%s\\Heads\\heads.ini", SaveDataPath);
	int fileExist = 0;
	int fileSize = 0;
	// if file doesn't exist return 0;
	fileExist = FileExists (path, &fileSize);
	if (fileExist == 0)
		return -1;
	IniText iniTextFile;
	iniTextFile = Ini_New(0);
	int status = Ini_ReadFromFile (iniTextFile, path);
	if(status != 0)
		printf("status - %d.\n", status);
	int numberOfSections = Ini_NumberOfSections(iniTextFile);
Message 1 of 1
(1,022 Views)
