Hello, I have problem with using Ini_ReadFromFile function.
If I build project in Debug64 version everything works fine.
But in Release64 version function return -5001 result (Could not open file for reading).
Here is code that cause problem:
int section;
char path[MAX_PATHNAME_LEN];
sprintf(path, "%s\\Heads\\heads.ini", SaveDataPath);
int fileExist = 0;
int fileSize = 0;
// if file doesn't exist return 0;
fileExist = FileExists (path, &fileSize);
if (fileExist == 0)
return -1;
IniText iniTextFile;
iniTextFile = Ini_New(0);
int status = Ini_ReadFromFile (iniTextFile, path);
if(status != 0)
printf("status - %d.\n", status);
int numberOfSections = Ini_NumberOfSections(iniTextFile);
