09-05-2016 03:47 AM
the command in the subject is from a older version. Now I searched for the identical command in CVI 2015 but I didn't found it.
Does somebody know where I can find it or if there is a list where I can see the updated command in an overview. I startet with CVI 2015 but in the examples are often commands from the older versions and it is difficult to search for all them.
Best regards
09-05-2016 04:23 AM - edited 09-05-2016 04:23 AM
Since this is a task attribute, you can find the correct command digging into the list of available attributes in DAQmxGetTaskAttribute. Specifically, what you need is:
DAQmxGetTaskAttribute (taskHandle, DAQmx_Task_NumChans, &numChannels);
