LabWindows/CVI
DBConnect fail
DBConnect return -100;
When I move my released program to another computer, DBConnect failed and return -100.
But the program run OK on the computer where I build.
The computer where I move the program to has installed MS Access 2003,Word 2003, Excel 2003.
the code:
DBInit (DB_INIT_SINGLETHREADED);
 char CurrentPath[MAX_PATH];
 GetProjectDir(CurrentPath);
 char DBConStr[MAX_PATH];
 sprintf(DBConStr,"Provider=Microsoft.Jet.OLEDB.4.0;Data Source=%s\\%s;Persist Security Info=False",CurrentPath,"Result.mdb");
 DBhandle=DBConnect(DBConStr);
(4,034 Views)
Hi JohndyWu,
you may need to read Distributing an SQL Toolkit executable or DLL topic in the toolkit help: there you can find hints about creating a distribution that installs all necessary support files on the target machine.
Unfortunately I have used it only for small tests so I cannot help you more than this.
(4,028 Views)
