LabWindows/CVI
DLL load fails depending on CVI installation
Hi I have a large CVI DLL 7.1.1 which is called from a VC.NET project.  When I build the CVI DLL on one computer everything works.   I take the whole project directory to another computer, recompile, and it fails to load the DLL.  The DLL load fails.  It can find the dll entrypoint but cannot find the first function that is called from the application.  The dependency walker sees all the exported functions but when tracing the DLL load shows that it fails at some point.  What setting do I need to change in CVI on the one computer to make it work better?  What settings are not carried with the project workspace?
DS
(2,568 Views)
So I took a risk to see if I could build my latest code on the other PC and it built fine and is now distributed.  I guess now I will try to reinstall CVI and see if that helps.
(2,558 Views)
