LabWindows/CVI
Daqmx acquisition tutorial
I'd like to find a DaqMx tutorial for LabwindowsCVI because I am a CVI newbie.
Olivier
(4,067 Views)
You will find some basic informations about DAQmx in many languages including CVI in this document: Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisition Applications
Another useful document can be Using the DAQ Assistant in LabWindows/CVI
These documents can be a basis to help you understand the CVI samples that are installed together with DAQmx and are located in <cvidir>\samples\DAQmx folder. I suggest you to take and execute some of them in order to begin practicing with DAQmx.
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
(4,057 Views)
 Hi Olivier,
 Roberto B. has made some very good suggestions. Looking at how LabWindows & DAQmx work together can be seen very well in the examples that are installed when you install LabWindows. I would probably start with the examples from the NI Example Finder, as seen here.
 Have a great afternoon,
 MatthewW
 Applications Engineer
(4,035 Views)
