LabWindows/CVI
Denkovi DAEnetIP4 web enable Controller
Does anybody had experience with Denkovi DAEnetIP4 in Labwindows CVI Environment?
levieg
(3,661 Views)
Accepted by levieg
Hi levieg
While I haven't worked with the Denkovi DAEnetIP4, I've been looking into the product on Denkovi's website and have not seen support mentioned for ANSI C. Because LabWindows™/CVI™ uses ANSI C, I'm not sure that this is the best method to work with that controller. Because this issue is more related to the ANSI C language than with LabWindows/CVI, I would recommend getting in contact with Denkovi to see what options you have for working in ANSI C. If during this process you encounter problems that are specific to LabWindows/CVI and this product, I will do my best to assist you!
Otherwise, if you can find a way to use the C# or C++ examples on Denkovi's website with LabWindows/CVI, I'm sure that anyone visiting the forums would appreciate any insight or tips that you could glean from working on this project!
Andy F.
Applications Engineering
(3,631 Views)
Hi andy,
Thank you very much,
Is writing a SNMT Driver in CVI is a tough time consuming task (minmum two weeks programer work)?
levieg.
Test Engineer
(3,621 Views)
