06-06-2017 04:13 AM
How to establish the communication when two instrument are sharing the data through Ethernet ?
can someone share sample project in CVI environment?
06-06-2017 06:53 AM - edited 06-06-2017 06:56 AM
What do you mean with this? Do you want to communicate with two different instruments on the same network, or with one only (considering your program as the second "instrument") or there are two instruments already connected and you want to monitor the communication between them?
CVI comes with some example of communication via TCP/IP that you may start looking at: search for "TCP" in the example finder to locate them (Help >> Find examples... menu function)
06-06-2017 06:56 AM
i want to communicate with two different instruments on the same network
06-06-2017 07:02 AM
So basically you need to open two independent connections, one for each instrument.
First of all, you need to locate the documentation that explains communications capabilities for your instruments, or better search in the Instrument Driver Network if any instrument already exists for your instruments. Take a look also to this support page, where informations are given on instrument drivers to use for communicating with external devices.
06-06-2017 07:23 AM
thanks for the help.
